I posted this a few days ago in the WIndchill Solution area however no one provided an answer to my question. I am hoping someone in this forum may know the answer.
If auser opens a Pro/Engineer file in Winchill using via a standalone browser and Pro/Engineer is not already open, Pro/Engineer is started without all of our typical customizations. How do I correct this?
P.S. We are on Windchill 9.0.
TIA,
Mark Bohannon
Some additional information.....
We already have the config files in the text folder. That is not the issue. Theproblem is that our normal method to start Pro/E uses a batch file that sets the working directory, declares some environment values, and performs various system checks before starting Pro/E. I want Windchill to start Pro/E using the same batch file method. CurrentlyWindchill starts Pro/E using the OOTB method with the working directory as the desktop which leaves trail files and other things on the user desktop.
