Problem Installating Creo 2.0
ptc-4919983
HI
I installed creo 2.0 a while ago, around a month later the program wouldn't open fully due to some license error.
I reinstalled it and the same thing has happened.
Can anyone help me>?
6 REPLIES 6
Daniel,
show us the contents of C:\ProgramData\PTC\Licensing\sw_license_email_1786189.dat file and also the contents of parametric.psf file (search Creo 2 installation dir).
Martin Hanak
Martin Hanák
The Parametric .psf contents are here
The license file is here
Cheers
Daniel,
it seems to me that both files are correct.
So let us return to your picture. First error messages tells us:
C:\ProgramData\PTC\Licensing\sw_license_email_1786189.dat: (-9) Invalid host.
The hostid of this system does not match the hostid specified in the license file.
Please check MAC address of your network card ... it must be A4-BA-DB-FA-E5-67
To do the check, you can open DOS prompt window and run the following command
ipconfig /all
Martin Hanak
Martin Hanák
strange...
it saids...
for wireless Lan Adapter wi-Fi2
Physical Address : 24-77-03-DD-AB-5C
Daniel,
if you have a notebook then you know that it has two network card - LAN and WiFi. If your notebook is not connected to LAN cable, then LAN network card is disconnected or disabled and Creo is not able to find it.
Try to connect LAN cable to your notebook, restart it and try to run Creo.
What Windows version do you use ?
Martin Hanak
Martin Hanák
