I have a problem with the mapkeys in Creo and 3DConnexion devices.
Before, I was using an old SpacePilot and all my mapkeys assigned to the buttons worked well.
Now I have an SpacePilot Pro and a SpaceMouse Pro in different PCs. Some mapkeys doesn't work. An error window in Creo shows "Illegal characters in input. Re-enter:"
This happens in Creo Parametric 2.0 M250 and Creo Parametric 3.0 M090.
The drivers are updated to 3DxWare64_v10-5-5_r2759.
PCs with Windows 7 Pro and Windows 8.1.
An example of mapkey that doesen't work:
mapkey drw @MAPKEY_LABELBrowse_DRW;~ Command `ProCmdModelOpen` ;\
mapkey(continued) ~ Trail `UI Desktop` `UI Desktop` `DLG_PREVIEW_POST` `file_open`;\
mapkey(continued) ~ Open `file_open` `Type`;~ Close `file_open` `Type`;\
mapkey(continued) ~ Select `file_open` `Type`1 `db_4`;
Any help?
Thanks!
