Problems with m080 download?
davehaigh
I'm having some issue with the download of m080. Anyone else have this issue?
When I unzip it, I get this error.
[cid:image004.png@01CEE114.E26F3EE0]
[cid:image005.png@01CEE115.7B64A7C0]
If I pick View Output, I see this error:
Extracting ptc308.cab
Extracting ptc309.cab
CRC check failed
Extracting ptc31.cab
Extracting ptc310.cab
Size of the file is:
[cid:image004.png@01CEE115.7B64A7C0]
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
14 REPLIES 14
davehaigh
(To:davehaigh)
By the way, so far, I used Chrome, IE 9.0, and Mozilla to do the download.
David Haigh
You should only extract the top level of the ZIP. Anything below the top level should not be extracted. CAB files are compressed repositories used by the Installer.
Ed Huffman
Senior Consultant
ProductSpace Solutions Inc.
Phone: 630-495-2999, x8106
Follow us at
I downloaded on 10/28 with Firefox and unpacked with WinRAR without issue.
James
davehaigh
(To:davehaigh)
It appears I'm not the only one having problems getting a good download. PTC suggested trying WinRAR. Which I did, and received the same error.
Checksum error in E:\virtual_box_P_drive\Creo 2.0-m080\Creo 2.0-m080 software\ptcsh0\ptc309.cab. The file is corrupt.
Turns out that even though the last time I installed the software I got no errors, it didn't install xtop down in the load point.
<load point=">\Creo 2.0\Common Files\M070\x86e_win64\obj\xtop.exe
Hense the reason it wouldn't start up.
I went ahead and ordered physical media.
David Haigh
I just downloaded via HTTP IE 9 WIN 7 64BIT. All files extracted and the install went flawlessly.
Bryan Bruder
Administrator - Engineering Systems
Product Development
Markem-Imaje USA
Tel. 00 (1) 603 283 2881
www.markem-imaje.com
This e-mail message and any attachments are proprietary or confidential, are solely for the use of the intended recipient, and may be privileged. If you are not the intended recipient, any review, use, dissemination or copying of the message or associated attachments is prohibited. If you have received this email in error, please contact the sender immediately and also delete the communication from your system. Thank you.
Nothing contained within this e-mail, including attachments, is intended to include or constitute an "electronic signature" as defined in 15 U.S.C. § 7006(5).
davehaigh
(To:davehaigh)
Hummm. I guess even though we have one of fastest computer on the planet, our network connection to the outside isn't all it could be.
David Haigh
I downloaded via HTTP as well from Chrome on Win7 64 and extracted with 7zip and had no problems.
I didn't use the "extract" command, I opened the zip in 7zip and dragged the contents into the Windows Explorer folder.
LinkedIn
My tool of choice is 7Zip.
Ed Huffman
Senior Consultant
Follow us at
j0sizemore
(To:davehaigh)
I downloaded M080 Wednesday night from Win7 64bit IE 9, unzipped with Winzip 16and installed it today with no problems.
llie
(To:davehaigh)
All,
I agree with Joanna, we have never had a problem using Winzip.
We have seen issues with unzipping files using Windows Explorer. Not all of
the files will be unzipped and you wouldn't know it.
Lance J Lie
Information Technology
SAS IT Info. Solutions App. Eng.
Space and Airborne Systems
Raytheon Company
+1 310.616.1551 (office)
+1 310.426.4968 (cell)
+1 310.647.0315 (fax)
2000 E. El Segundo Blvd.
El Segundo, CA 90245 USA
www.raytheon.com
Raytheon Sustainability
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this
message in error, please so advise the sender by reply e-mail and delete
this message. Thank you for your cooperation.
Had an issue downloading through download manager and IE, used Chrome and
it was fine
Go figure!
Can't download M080 w/ IE9 and Download Manager. Get error message. Gave up and ordered media.
STEVEG
(To:davehaigh)
I got the same thing. When you download it you have the option of download manager or HTTPS. I HTTPS and it was fine.
Stephen Galayda
CAD/PDM Administrator
HydraForce, Inc.
(847) 229-3188
davehaigh
(To:davehaigh)
So it appears after all my frustration with m080 downloads and ordering the media and getting it ready to roll out, I have to now wait for m090.
This came from our TSAM this morning:
