Proxy configuration message
ajadhav-2
6-Contributor
I was able to login in PTC Creo element direct modelling 6.0 successfully till day before yesterday, but while login in today I am getting a proxy configuration message. Also i am having good internet connectivity and have also tried requesting manual activation but web-page shows that it is under maintenance.
As i was unable to find an solution to this error in any other related topic, so i had to re-create this topic.
Best Regards,
Anandraj Jadhav
2 REPLIES 2
I just tried logging in today as well.  I also come across the same issue.  It appears that Creo support servers are down.  Does anyone know how long it will be to bring these back on line?
ajadhav-2
6-Contributor
(To:invalidflaw)
The problem is solved, i am able to login in successfully in Creo elements.
Anand
