Anyone have a purge executable/program that does NOT require administrator privledges? I mostly work in Windchill, but on occasion work off line and it would be nice to be able to clean up my directories. I thought I had a TrueUtilities executable, but it's only an installation program and need admin privledge to run.
thanks in advance...
This only works if the location of the built in purge.bat file is in your system PATH variable. Sadly, that takes administration to do if it's not...
In Reply to David Haigh:
Use the built in purge command. No you don't get to choose how many versions to keep. You just get the latest of each file.
Pick the magnifying glass in the upper right of Creo
Type in sys, then pick Open System Window. (for some reason they have hidden the command in Creo. It used to be in the pull down menus)
[cid:image001.png@01CF6B61.283A41A0]
That opens up a command prompt in the directory that is your current working directory. This command window also has any environment variables that were set when Creo was launched.
I naturally assume since you're working standalone that you have set your work directory to where your files are.
Type "purge" in the command window and then exit the window. You can type "exit" since your hands are already on the keyboard. Done!
It's worked this way since the beginning.
David Haigh
