Retrieve/Continue panel
pdiletti-2
Hi
after CREO stops in a not regular way,
and you start again, a "Retrieval" panel appears with two available options
"Retrieve " and "Continue"
Is it possible, using a config.pro option, to avoid this kind of panel appears ?
Thanks a lot
Pier
gkoch
(To:pdiletti-2)
Try config.pro option last_session_retrieval no
