Revision Table Row Font
RussellLudwick
I am working on a drawing format, and I am trying to setup the revision table so that when you add a row it keeps the settings from the table instead of going to the default. It keeps wanting to default to the pro E "font" and size. I would like to use one of the other fonts like "CG Triverium".
Another problem I am having is trying to set the default font to CG Triverium in the drawing options. The only font I am finding in the dropdown menu is "font", Do I need to add the fonts to the server where the drawing options are located? Where would I find the configuration that sets the path to the folder I should add fonts to to be able to select them.
0 REPLIES 0
