SOLVED 3D Note annotations
rrich
2-Explorer
Thanks to Janet who told me about a config option I mean hidden config option it now works as planned. NOTE: if you search for this config it will not show up. You must just add it to your config at least once then the toggle on and off and tag toggle under options entity display work as expected.
I guess it is time to expect the unexpected.
bfrandsen
(To:rrich)
A better solution is to delete the option from your config.pro as it has been obsoleted. Deleting it is the same as setting it to yes according to CS22006.
/Bjarne
rrich
2-Explorer
(To:rrich)
Not the case for me I did not have this in the config and it was broke. I had to add it to get it to work.
Ron
bfrandsen
(To:rrich)
I do not have it in my config and I have no issues with 3D annotation. I am using Creo 2.0 by the way.
/Bjarne
