how to Install creo2.0 m010 to m05o
aminhas
any buddy have details document for this?
Creo 2.0 M050 lnstall like M010,but you should remove M010 or not remove.I'm Suggestion that You had better remove M010.
Have a look at this thread. It has a lot of good information.
Creo 2.0 M020 is out: report your update experience.
In general, yes, remove everything using the windows uninstall and download the full install file. unzip to an install folder and run the setup program.
be careful not to loose files you created and placed in the Creo loadpoint. They will disappear forever when you uninstall the program.
