The server that hosts our Model Manager Server has changed to a new domain. I have changed the addresses of the servers in my xml file in the config folder on the server however the getnrun.ini file on the clients still points to the old domain address (which cannot be resolved) on fresh Model Manager client installs. I can manually change the url in the getnrun file and Model Manager will then startup with no problem. Does anyone know how can I get the Model Manager clients to install with the proper address? Where else do I have to change the server domain address? Thanks for your help.
Sorry for the late response, I hope you already found it!
Just look at the mmbuild.nsi script in the clntwin folder. There the contents of the getnrun.ini file is created.
Take also into account that, if you are using Oracle, you will probably also have to change some Oracle configuration files like tnsnames.ora
