Setup.exe doesnt work
JS_12816833
7-Bedrock
When i click setup.exe it doesnt open anything it just loads for 2 seconds and disapear. I tried turning off firewall, cmd commands, different Creo versions from 11.0-8.0 and nothing works. Help
I found the problem. File has to be in ThisCompuper/Windows(C:)/... and I had it on desktop. Here is the solution if it helps anyone.
3 REPLIES 3
Hi @JS_12816833
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry.
Please include screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Furthermore, please consult this Community Search guideline as well, which boosts up your chances of finding a resolution to your topic(s) much faster.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina
PTC Community Moderator
PTC
I guess that setup.exe did not start from desktop, because path to desktop contains non-ASCII characters.
Martin Hanák
