I'd like to assign hotkeys in Creo 7.0.0., but somehow it doesn't work.
I did the following:
1. Click File > Options to open the dialog box.2. Under Customize, select the customization page for which you want to assign keyboard shortcuts.3. Under the Shortcut column, click the cell. Enter the shortcut key in the cell.When I click the cell, nothing happens and Creo doesn't let me put the shortcut in.Maybe somebody has an idea, why I can't type anything in the cells ?Thanks,
in Creo Parametric 7.0.2.0 I am able to assign a shortcut.
