Summary: Run Batch file after Creo exit
dgschaefer
I received some great responses (detailed below) but in the end I punted and went with this simple strategy (run at launch):
xcopy /q /y /e /d %proe_user_cache_bu%*.xml %proe_user_cache%
xcopy /q /y /e /d %proe_user_cache_bu%*.ui %proe_user_cache%
xcopy /q /y /e /d %proe_user_cache%*.xml %proe_user_cache_bu%
xcopy /q /y /e /d %proe_user_cache%*.ui %proe_user_cache_bu%
proe_user_chache is the server folder, proe_user_chache_bu is the local cache.  So, I copy local to server (if newer) then copy server to local (if newer).  I think this should make sure the newest file is in both places.
The only situation that doesn't cover is a user logging onto a shared workstation and making a change to their UI file or adding a favorite and then returning to their own PC.  They would not get their updates since this isn't run until the next launch of Creo.  That's a rare event and a limitation I can live with and was quick to implement.  Re-launching Creo before they log off or returning to the shared workstation and launching Creo should fix it if needed.  Typically, changes made on a shared workstation are small and easy to redo.
Original question & responses below.
LinkedIn
0 REPLIES 0
