Hi Chris,
you can use configuration file from previous release of ProE into new version.
System automatically recognize if the configuration options are OK or not.
Old (not working) options are marked with sign .
You can really easy repair loaded config.pro file directly in ProE WF5 (creo elements pro 5.0) - Tools > Options >> select old configuration opton >> DELETE
... or you can add new option(s).
Note: Do not forget save the file
The complete list of Configuration Options for Pro/E WF5 - Creo Elements Pro 5.0 you can find here: 4K Side | Configuration options - Pro/ENGINEER Wildfire 5.0
