We recently updated our license file to WF5, and we received 2 files, lm_###_standard.txt and lm_###.txt. In the email it mentions that the standard (lm_###_standard.txt) i sbackwards compatible, but does NOT allow license borrowing, if you use license borrowing you will use the other license file (lm_###.txt), however the file which allows license borrowing is NOT backwards compatable. As we do not utilize the license borrowing we installed the standard file and are capable of running WF5, 4, and 3.
