When using VPN, Creo cannot connect to the corresponding license. It prompts 7788@xxxx (-9) Invalid
XZ_10393809
I am using Creo Parametric Release 4.0 and DatecodeM130
使用VPN时,Creo无法连接对应的License.提示7788@xxxx (-9)Invalid host.(license服务器所在电脑已开放7788端口)
When using VPN, Creo cannot connect to the corresponding license. It prompts 7788@xxxx (-9) Invalid host. (The computer where the license server is located has opened port 7788)
Prompt 7788@xxxx (-9) Invalid host
Translated by Iuliana Lazar with Google Translate on 17 Oct 2022
1. Article - "How to access Flexnet based PTC products via VPN": https://www.ptc.com/en/support/article/CS119513
2. Discussion - "VPN Issue": https://community.ptc.com/t5/System-Administration/VPN-Issue/td-p/422133
