Which file define the $PRO_DIRECTORY variable path?
jlee-10-11-12
I can find these two variables in config.pro file, but in which file define these two variables' path?
Usually we define path like this ENV=PRO_DIRECTORY=D:\SAMPLE FOLDER. but i can't find this definition in all .bat files and .psf files.
  • $PRO_DIRECTORY
  • $CREO_COMMON_FILES
I guess that Creo creates these local variables automatically, when you start new session.
Martin Hanák
4 REPLIES 4
Martin Hanák
I agree with you, because i tried to find all .bat and .psf files but can't find these variables.
You will see the following snippet in a number of batch files in the Creo app directory (<loadpoint>\parametric etc.):
### Creo 4.0 ###
set APPDIR=%~dp0.. set cf=%~dp0..\.. set PRODIR=%cf%\Common Files
set PRO_DIRECTORY=%PRODIR%
### Creo 2.0 ###
set APPDIR=%~dp0..
set cf=%~dp0..\..
set PRODIR=%cf%\Common Files\M240
I assume one of the batch files is called during Creo startup prior to processing the PSF file.
I found these files contain the variables.
Thank you for your help.
----------  D:\Program Files\PTC\Creo 4.0\M020\Parametric\bin\convert_image.bat
[40]     set PRO_DIRECTORY=%PRODIR%
----------  D:\Program Files\PTC\Creo 4.0\M020\Parametric\bin\dcadsetup.bat
----------  D:\Program Files\PTC\Creo 4.0\M020\Parametric\bin\dcadshutdown.bat
----------  D:\Program Files\PTC\Creo 4.0\M020\Parametric\bin\modelcheck.bat
----------  D:\Program Files\PTC\Creo 4.0\M020\Parametric\bin\parametric_borrow.bat
----------  D:\Program Files\PTC\Creo 4.0\M020\Parametric\bin\procvtutil.bat
----------  D:\Program Files\PTC\Creo 4.0\M020\Parametric\bin\prodialog_view.bat
----------  D:\Program Files\PTC\Creo 4.0\M020\Parametric\bin\proev.bat
----------  D:\Program Files\PTC\Creo 4.0\M020\Parametric\bin\progpostg.bat
----------  D:\Program Files\PTC\Creo 4.0\M020\Parametric\bin\progpostl.bat
----------  D:\Program Files\PTC\Creo 4.0\M020\Parametric\bin\progpostq.bat
----------  D:\Program Files\PTC\Creo 4.0\M020\Parametric\bin\propostg.bat
----------  D:\Program Files\PTC\Creo 4.0\M020\Parametric\bin\propostl.bat
----------  D:\Program Files\PTC\Creo 4.0\M020\Parametric\bin\propostq.bat
----------  D:\Program Files\PTC\Creo 4.0\M020\Parametric\bin\protab.bat
----------  D:\Program Files\PTC\Creo 4.0\M020\Parametric\bin\protk_unlock.bat
----------  D:\Program Files\PTC\Creo 4.0\M020\Parametric\bin\pro_mcs_comp.bat
----------  D:\Program Files\PTC\Creo 4.0\M020\Parametric\bin\pro_ncl_cvt.bat
----------  D:\Program Files\PTC\Creo 4.0\M020\Parametric\bin\ptcborrow.bat
----------  D:\Program Files\PTC\Creo 4.0\M020\Parametric\bin\ptcdbatch.bat
----------  D:\Program Files\PTC\Creo 4.0\M020\Parametric\bin\ptcflush.bat
----------  D:\Program Files\PTC\Creo 4.0\M020\Parametric\bin\ptchostid.bat
----------  D:\Program Files\PTC\Creo 4.0\M020\Parametric\bin\ptcstatus.bat
----------  D:\Program Files\PTC\Creo 4.0\M020\Parametric\bin\purge.bat
----------  D:\Program Files\PTC\Creo 4.0\M020\Parametric\bin\vb_api_register.bat
----------  D:\Program Files\PTC\Creo 4.0\M020\Parametric\bin\vb_api_unregister.bat
----------  D:\Program Files\PTC\Creo 4.0\M020\Parametric\bin\pim\xml\creo_templates.xml
[66]     set PRO_DIRECTORY=%PRODIR%
[114]     set PRO_DIRECTORY=%PRODIR%
[951]       set PRO_DIRECTORY=%PRODIR%
Jeff
