Why does Creo 2.0 and 3.0 not works with Geforce GTX 960M ? How can i solve it ??
rreupke
How can help me?
you posted your question on Creo/Elements Direct area. Do you use this software or Creo Parametric ?
MH
Martin Hanák
I use Creo Parametric.
what happens, when you launch CR2/CR3 ?
Do you use PC or notebook ? What configuration ?
Which version of graphic card drivers is installed ?
Tip: Add following option at the end of config.pro file and do test.
graphics   win32_gdi
MH
Martin Hanák
