How is the config file updated to add the mold component folder so that it shows up in the common folder area of Creo 2?
Mark,
Are you looking for config option pro_library_dir? If you will install Mold library, set the config to library folder, this will add Mold library in common folders.
Mark,
Are you able to correct the Mold library issue?
