batch conversion from x_t to prt?
srajbhar
Hi There,
i have 200 to 500 x_t files that i need to convert to prt creo2 format...
can anybody please suggest how can i achive this with the help of scripts or tools etc..
any suggestions ideas are always welcome...
thanks!
3 REPLIES 3
Hi Shravan,
If you have a license, you should be able to install and use the Creo Distributed Batch program to batch import Parasolid (*.x_t) files, and save them as Creo Parametric .prt files.
Amit
Thanks! Amit
Hi Shravan,
If the method works for you, can you mark the response as the Correct Answer, so other users can find the  resolution quickly.
Amit
