batch conversion from x_t to prt?
  • October 18, 2016
  • 2506 views
Hi There,
i have 200 to 500 x_t files that i need to convert to prt creo2 format...
can anybody please suggest how can i achive this with the help of scripts or tools etc..
any suggestions ideas are always welcome...
thanks!
18-Opal
October 18, 2016
Hi Shravan,
If you have a license, you should be able to install and use the Creo Distributed Batch program to batch import Parasolid (*.x_t) files, and save them as Creo Parametric .prt files.
Amit
srajbhar1-VisitorAuthor
Thanks! Amit
18-Opal
October 25, 2016
Hi Shravan,
If the method works for you, can you mark the response as the Correct Answer, so other users can find the  resolution quickly.
Amit
