clipping diameter dimensions
cdown
7-Bedrock
I'm back on to wildfire, I have a segmented part and am trying to show the diameter as a clipped dim but I can seem to get this to happen?
Is there a config setting to allow this? its been a while so can't remember
4 REPLIES 4
Hi Colin,
Which release of Wildfire are you using?
Amit
Sorry forgot to mention WF4 M220
Hi Colin,
To create a clipped dimension do the following:
  1. Select a reference
  2. Hold down the CTRL button and select a 2nd reference
  3. Continuing to hold down the CTRL button, select the 1st reference again
  4. Use the MMB to place the dimension
Let me know if that doesn't work.
Amit
Amit's method is for a created dimension.  For a shown dimension, use show as linear, and clip witness line (from the dimension properties dialog), IIRC.
