custom map key file load / custom map keys stopped working
bmclees
I am using Creo Parametric Release 11.0 and Datecode11.0.0.0
custom map keys not working after new creo install. creo_parametric_customization.ui file did not change.
start up load directory the same.
5 REPLIES 5
BenLoosli
(To:bmclees)
Mapkeys are moved to mapkey.pro file from your config.pro file the first time you run Creo 11.
When you start Creo 11, you get a warning that mapkeys have been moved to mapkey.pro and are NOT loaded from your local config.pro anymore.
tbraxton
(To:bmclees)
Read these threads: Creo11 and Mapkey.pro - PTC Community
If you use any mapkeys that call other mapkeys on the fly: Mapkey toggle scheme no longer works in Creo 11+ - PTC Community
Involute Development, LLC
Consulting Engineers
bmclees
(To:MartinHanak)
Thank you for the information.
In the future when installing new versions of Creo Parametric how do you keep the mapkeys.pro file? Will this be saved or deleted?
Q: Will this be saved or deleted?
A: I don't have a definite answer. It's always a good idea to make a backup.
Martin Hanák
