dashed line display during assembly
JLG
Using Creo Parametric 2:
One of my coworkers does not see a red dashed line when assembling components (but I do). To be specific, first select a surface on the component being assembled, and then a dashed line appears from that surface to the cursor until you select an assembly reference. (See attached picture.)
Does anybody know what controls this? Is there a config option? Is it gremlins?
Thanks for any help you can give.
Best regards,
Janet Grove
davehaigh
(To:JLG)
Try setting the config.pro graphics to
graphics win32_gdi
If that fixes the problem then it's a graphics card issue.
David Haigh
JLG
(To:JLG)
Thanks for the great suggestion, David. I'll have to keep that one in mind for future problems.
It turns out I had pre-selection highlighting turned on (and I could see the line) and my coworker did not (and he didn't see the line). It's a pretty simple fix to toggle it on.
Thanks again!
Best regards,
Janet Grove
In Reply to David Haigh:
graphics win32_gdi
David Haigh
