Hello AS_10538336,
As Martin mentioned, the behavior you described is the intended behavior with Creo Parametric Cables / Wires.
Cables / Wires display are cosmetic surface representation and not solid features.
You have the possibility to vote for Idea 779705 reporting such enhancement request.
As mentioned by Vivek, feel free to close this discussion if it's ok for you.
best regards
Jean-Claude
I guess this is current Creo functionality. Please ask PTC Support to verify this idea.
Hello AS_10538336,
best regards
Jean-Claude
