good desktop computer
LisaJ
Hi. I'm looking into buying a desktop and was wanting some good suggestions on what works good. Also, will proe still run if the computer has windows 7 home premium? (in the compatibility info. it didn't list windows 7 home premium as compatible)
2 REPLIES 2
James62
(To:LisaJ)
hi Lisa,
Check this pdf http://www.ptc.com/WCMS/files/77552/en/proewf5.pdf
I am not sure what do they mean by Enterprise Edition to be honest. From my own experience I can only assure you it works on Professional and Ultimate, but I still think it should run on Home Premium too.
Following table is from PDF that comes with WF5 Schools edition
since there is no Win7 Home Premium mentioned I wouldn't use it. The user rights are the problem. I've read some threads that users have the combination WF5/W7 HP but there are also written statements from other users that this won't work.
It seems to work if you change some settings:
http://ww3.cad.de/foren/ubb/Forum12/HTML/020560.shtml
It's a german thread where everything is described. Maybe it helps.
