i am facing a problem in saving efx extension file . file is attached
Hi Sagar,
EFX file extension is same as of parts and assembly (.prt and .asm) for Creo Parametric 2.0. When you will save a Frame assembly extension will be *.asm and frames/parts will save as *.prt.
Mahesh
Hi Sagar,
Mahesh
mahesh is right abt extension. However I faced similar problem like creating the efx elements but couldnt save and that was becasue i overlooked the non saving of un regenerated models. Alos check you have full afx license instead of afx lite.
