invalid feature name
jjakubos
I had Creo III installed for FIRST robotics use on office CPU's.  When I try to open it it gives me the following error:
License request failed for feature
Invalid feature name:[FEATURE_NAME]
Can anyone help?
Jim,
This error will prompt when Creo is installed without specifying the license information (server or license file).
To correct this, reconfigure Creo by executing reconfigure.exe from <Installation location>\parametric\bin and specify the server under license identification as 7788@servername (if license is on server) OR drag and drop the license file (for locked license)
Thank You!  Solved our issue!
I did in fact skip license step.
I was trying to simply define the license parameter as a System Env. Variable but it would not work.
PTC_D_LICENSE_FILE=
So the reconfigure and defining our node locked license as directed above fixed our issue.
Thanks again!
Paul
Durga
(To:Mahesh_Sharma)
Thnx this works
