I have customer still using creo 2.0 M120 and me I want use 3.0.
Can we keep both version???
Bests Regards.
Francois
Hi I install last week both version of creo and they run well. thanks all for answer
Yes, just install into a different root folder.
thanks you
thanks you
yes bro,.........
but u instel in different os. if u do not then it will hang ?
You can have both versions installed and they will both work (I have both installed right now).
Keep in mind though that they are not backwards compatible like most Microsoft Office products are. As soon as you save something in the newer version you will not be able to open it in an older version. The caveat to this statement is that there is a complicated plugin that does allow you to open newer files with the older versions but it does not restore full functionality. It only allows you to add features in the older version which you can then use in the newer version. It also doesn't always work correctly.
Yes I saw this I open with my M060 drawing M120 and had some red things and my went I resend the drawing the red things disapear. ![]()
Nice answers thanks you.
thanks all
you can installed both version in one system, like w-7,8.1,8 , XP etc like ,then u can easilly work
yes ok thanks
most wellcom
Otherwise u uninstalled creo 2, then after installed creo 3, this is the batter way bro............
I want keep 2.0 only for this customer. Now I had install M120 and try install 3.0 M040.
But I'm affread to erase the possibility to work with this customer who keep 2.0.
Now with all your answer I known is it possible.
thanks all
no no don't worry .......... nothing deleted ............carry on........................
As others have said, there's no issue with installing multiple versions. I have WF4, WF5 and Creo 2 on my machine right now. All my work is in Creo 2 at the moment, but like you, I need to be able to use what my customer uses.
Some things to keep in mind, however.
Francois,
You may mark appropriate replay to post as correct answer or add more information to post to mark that as correct answer.
yes
