Happy Monday all,
Not sure how much of this is Windchill and how much Pro/E configuration.
But the situation is this: some users when in IE windchill cangoto the Action Menuof a Pro/E file and select 'Open in Pro/Engineer' and it will comply. Others will do the same thing and ProductView will launch. Where oh where have I gone wrong? Got a feeling this will bea forehead slapper.
Thanks for your attention,
Bob Lohbauer
Jacobs Vehicle Systems
Bob,
The browser calls the application registered as the default for the specific file type on your computer. If your users are selecting the same icon on the same Windchill page but getting different applications on different computers, then the variation you are seeing is caused by your users' registry settings. Probably the easiest solution is to run ptcsetup.bat (Pro/E) or reconfigure.exe (Creo Parametric) and let it update the registry entries on the computers that are defaulting to Creo View.
Kind Regards,
Matt Meadows
Solutions Architect
VIRSO Inc
O: 618 937 8115
C: 314 749 8377
E: mmeadows@virsoinc.com
My apologies. This thread had been most thoroughly answered and I never circled back to thanks those who replied. My error was in 9.1 the file type associations were pointing to ProductView (CreoView) not Pro/E. The regedits did the trick.
Matt Meadows and David Haigh both helped with answers that yielded benefits beyound the initial question.
