hi
can any one tell me to run model check through batch mode. I am giving name of parts , asm, drw in a text file, but i cant understand from where the library to check model is picked by modelcheck. or may be this text file is to be placed inside the library folder. I am trying this but its not working..
I put everything in the same folder, modelcheck.bat, parametric.bat, part.lst and config.pro. Create a shortcut to modecheck.bat, change start in to your folder with all files. Copy parametric.bat to working folder. Add your config.pro if you wish, I do this so I can run a standalone modchk folder with my batch settings. Then you will need a list of files to run. number.prt.01 etc..
hello scottb
Can you give me an example of that list file in which part names are written , is it required to write down the part name in any specific format. I have converted a text file to .lst file and the names of the parts are mentioned in that file. And also i placed my .lst file , parametric.bat and modelcheck.bat in the working directory folder but it is not working.Not even creo is opening.
So my list files look like this
1234567.prt.51
7654321.prt.15
etc etc, I have a batch file that will create a list of all files in a folder.
So two things to check, does your Creo start without asking any questions?
Our modelcheck.bat lives in a read only folder. So we must change the start in location to make it work.
Other things to look at, where are your modelcheck files getting wrote?
We change this file when we wish to put the reports in a different directory. config_init.mc
# Directory ModelCHECK will write reports on NT
DIR_REPORT_NT $TEMP/mc_reports
We use parametric.bat to run other tools, not sure how you start your Creo session typically, but I would use the same one you run to create your models.
