@JVerhagen78,
Make sure you have licenses #333 + #334 OR #14 + #335 added to your *.psf file.
Make sure you do not modify existing creotk.dat file.
Place shortcut of Creo Parametric at location "C:\PTC\Creo_8\Creo 8.0.3.0\Common Files\otk\otk_java\otk_java_examples". Remove path mentioned in Start in field of Creo's shortcut properties.
Launch Creo from this shortcut and check if the issue gets resolved or still persists.
@JVerhagen78,
Could you please share paths of examples which you tried loading in Creo?
Also, share snapshot of Auxiliary Application dialog after loading sample application.
@JVerhagen78,
