I am using Creo Parametric Release 5.0 and Datecode5.0.6.0
Good morning,
I need to know how to export and import parameters in CREO 5
Thank you.
Here are the errors that I faced
no sign of error
Translated by the Community Moderation using Google Translate
Buongiorno,
Ho bisogno di sapere come esportare e importare i parametri in CREO 5
Grazie.
nessun segno di errore
If you want to copy the parameters from one file to another, you can do that right in the parameter editor.
(1) Open the file you want to copy from.
(2) Select all the parameters you want to copy.
(3) Select Edit->Copy (I don't know the Italian menu selections)
(4) Open the file you want to copy the parameters into.
(5) Open parameter editor.
(6) Select Edit-Paste
It will paste them in, warning you if you are going to write over old values, etc.
Hopefully this is what you are looking for.
