please check Mapkey log
YK_TRIONNET_KR
I am using Creo Parametric Release 10.0 and Datecode10.0.0.0
Hello, I just made below mapkey yesterday. And I want modify it, I want add something between them.....sadly I can't remember how I did it...
can you explain them ??
mapkey ac @MAPKEY_LABELauto color;\
mapkey(continued) ~ Select `main_dlg_cur` `View:ProCmdViewGallery`;\
mapkey(continued) ~ Select `main_dlg_cur` \
mapkey(continued) `ProCmdViewGallery_layoutph.palette_holder.clearAppearance`;\
mapkey(continued) ~ Close `main_dlg_cur` \
mapkey(continued) ~ Activate `main_dlg_cur` `clearAllAppearance`;\
mapkey(continued) ~ Activate `UI Message Dialog` `yes`;
tbraxton
(To:YK_TRIONNET_KR)
It appears to invoke this command from the GUI.
Clear all apearancesClear all apearances
Involute Development, LLC
Consulting Engineers
tbraxton
(To:YK_TRIONNET_KR)
YK_TRIONNET_KR
(To:tbraxton)
Thank you for the reply first..
And can I ask you 1 more thing.
I want to know what is
mapkey(continued) ~ Close `main_dlg_cur` `View:ProCmdViewGallery`;\
mapkey(continued) ~ Command `ProCmdViewAppearanceEditor`;\
I really appreciate your reply
it would be nice from you to run mapkey and then find UI command related to it. It's not difficult and at least you'll learn something yourself.
Martin Hanák
