Any idea of the following error in the std.err file.
I believe because of this failure, the ProE is crashing.
WF version:WF3 M260.
std.err and std.out attached.
Maybe CS49331 helps you: https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS49331
I don't find a ptcportmap.bat file in the proe_loadpoint\bin directory.
I had WF5 installed in my machine earlier and have removed it. I am not sure if the uninstall have removed this portmapper service of WF5 version from registry.
Can't find from where it is running this service..
