hello
i am giving direct print of drawing from creo but print comes correct when i reduce the scale of drawing from 100% to 90% otherwise print doesnot comes right, is there any setting in config file or inside creo drawing envoirnment please help to find the solution..
I believe everyone has the same issue and more. The print routine is completely screwed up in Creo 3.0. It's as if no one at PTC ever tried to print a drawing while Creo 3.0 was under development. It's a very sad state when the most basic function is hosed in a software program of this stature.
I always set the scale to custom at 94% for each print I create. The other thing that EVERYBODY hates is the white background with yellow text and object lines in the print routine. I saw a posting recently that stated it would be corrected in Creo 4.0.
Bob
It's actually corrected in Creo 3.0 M090, due out on April 13th.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS197191
I also passes this problem with Creo 3.0 M90. I have solved creating a PDF drawing file. When creating the PDF I move the margins in X and Y for the drawing format clicks. Usually I move the margins in X and Y 0.12 or 3.
AFBG
