Hello;
I want to automate the process of regeneration in Creo. Is there any way to configure it in a way that it regenerate the model after every change to it or for example every 1 minutes?
Thanks.
BR.
Why do you want to do this?
Question from @manjunathrv is valid, why do you need this option. Time bound regeneration may lead to performance issue with large assemblies.
You may submit an Idea for the same with further details of having this option.
