The PTC Community will be on read only status starting March 23rd in preparation for moving our platform to a new provider. Read more here
sheetmetal settings in Wf5
gbon
Hi everybody,
I'm trying to update my starting parts with Wildfire5.
I'm not able to setup sheetmetal settings anymore.
With Wildfire 2, 3, 4, I could load a bend table from a file like this :
- Edit
- Setup
- Sheetmetal
- Bend Allow
then I could do what I wanted (set an existing table to my part, reset...)
Now, with Wildfire5, I just can define a new table, edit or show it.
I can't set an existing one.
So, is there something to do ?
Is .bnd file format have changed ?
GB
2 REPLIES 2
mlocascio
(To:gbon)
Correct me if I am wrong but the name of the function for "UNBEND" or "Flat
Pattern" has changed. That "may" be why you are having such a difficult time
with it.
Michael P. Locascio
gbon
(To:gbon)
Thank you but this is not the reason of my problem.
The menu Edit / Setup / Sheetmetal / Bend Allow / bend table is exactly the same.
However, since Wildfire5, some options are disabled :
define > ok
delete > disable
edit > ok
show > ok
write > disable
set > disable
reset > disable
done/return > ok
My config.pro also seems to be ok :
When I'm trying to define a new table called "stainless", for example, ProE tell me that it allready exist so I can't create it.
Effectively, a file named stainless.bnd exist in directory "pro_sheet_met_dir" so I assume settings are corrects.
However, "set" option is gray and I can't use it to choose this stainless.bnd setting file.
GB
----- Message d'origine -----
De : Michael P Locascio
À : 'g bon' ; -
Envoyé : mardi 5 octobre 2010 04:31
Objet : [proecad] - RE: sheetmetal settings in Wf5
Correct me if I am wrong but the name of the function for "UNBEND" or "Flat Pattern" has changed. That "may" be why you are having such a difficult time with it.
Michael P. Locascio
