sheetmetal settings in Wf5
gbon
Hi everybody,
I'm trying to update my starting parts with Wildfire5.
I'm not able to setup sheetmetal settings anymore.
With Wildfire 2, 3, 4, I could load a bend table from a file like this :
- Edit
- Setup
- Sheetmetal
- Bend Allow
then I could do what I wanted (set an existing table to my part, reset...)
Now, with Wildfire5, I just can define a new table, edit or show it.
I can't set an existing one.
So, is there something to do ?
Is .bnd file format have changed ?
GB
2 REPLIES 2
mlocascio
(To:gbon)
Correct me if I am wrong but the name of the function for "UNBEND" or "Flat
Pattern" has changed. That "may" be why you are having such a difficult time
with it.
Michael P. Locascio
gbon
(To:gbon)
Thank you but this is not the reason of my problem.
The menu Edit / Setup / Sheetmetal / Bend Allow / bend table is exactly the same.
However, since Wildfire5, some options are disabled :
define > ok
delete > disable
edit > ok
show > ok
write > disable
set > disable
reset > disable
done/return > ok
My config.pro also seems to be ok :
When I'm trying to define a new table called "stainless", for example, ProE tell me that it allready exist so I can't create it.
Effectively, a file named stainless.bnd exist in directory "pro_sheet_met_dir" so I assume settings are corrects.
However, "set" option is gray and I can't use it to choose this stainless.bnd setting file.
GB
----- Message d'origine -----
De : Michael P Locascio
À : 'g bon' ; -
Envoyé : mardi 5 octobre 2010 04:31
Objet : [proecad] - RE: sheetmetal settings in Wf5
Correct me if I am wrong but the name of the function for "UNBEND" or "Flat Pattern" has changed. That "may" be why you are having such a difficult time with it.
Michael P. Locascio
