software push...
ptc-4747774
software push...
hello all. Upgrading to Creo 2.0 and would like to know the difference bewteen Wildfire 5.0 and Creo 2.0, if any. Thanks, Justin
True wilfire 5 or the 1st implementation of the ribbon?
If the former: be prepared to post on all the "we hate ribbon" posts...
If the ladder: all your bugs are fixed.
Hi Justin,
Recently i also upgarded to creo 2.0, compared to ProE/WF 5.0 Creo have some additional user interface on ribbon.
  • In Render some additional rooms are given, that looks amazing for photo relaistic rendering.
  • Measure tool for measuring various geometry is good.
  • Annotate Ribbon is also good
  • Ribbon, hotkeys, and environment settings for configuring your workspace to your preferences.
  • Embedded command finder for quickly locating capabilities when you need them.
  • Intuitive 3D dragger, in-graphics toolbar, and mini toolbars for more efficient designing.
  • Use track changes capabilities to see exactly what has been modified within an assembly.
  • Work more quickly with streamlined new component placement constraints.
  • Save time and improve system performance by loading assemblies as Light Graphics representations.
  • Have more control with four new constraint types (normal constraints for surfaces, distance, angle offset, and normal constraints for points and lines).
  • Animate exploded and unexploded sequences.
for me Initially Ribbon interface is very hard...now it seems very easy
Vinoth
UNLOCK POTENTIAL with Creo Parametric 2.0 - Top 10 Reasons to Upgrade to Creo Parametric.pdf
Best Regards,
Vladimir Palffy
