We are using WF4, and ALT-TAB will cycle through the open ProEwindows, but it will not activate the window you choose.
An option that might help, though, is to add the (List of Current Windows) option to your menubar. This will allow you to not only change to another window with one click, but it will activate the window you choose. It took me a little while to get used to using it, but once I did, I like that I am one click from any open window. Thelist can be shown in the top menubar or on the side menubar. To add it, do the following:
<u>To Show a List of Current Windows:I have included a screen imageshowing six open documents. It is easy to see what is open,and I am only one clickaway from any of them.
In Reply to Lyle Beidler:
I can't believe that I've been a full-time pro/e user for nearly 10 years
and never thought of this before, but is there a keyboard shortcut for
toggling through pro/e windows (equivalent to Alt-Tab, but that works only
in pro/e windows)
Or a mapkey? Or something?
Thanks.
Lyle Beidler
MGS Inc
178 Muddy Creek Church Rd
Denver PA 17517
717-336-7528
Fax 717-336-0514
<mailto:-> -
<http://www.mgsincorporated.com> http://www.mgsincorporated.com
Brian,
I am using Windows7 and Pro/E. Look at attached file. Of coures, I am using Ctrl+A for actiavting Pro/E window.
Best regards
Radovan
Along the same lines, sort of, is using ALT-TAB to get to the window you want and then using CTRL-A to activate it. You're already using the keyboard in that area.
I am using windows 2000 and wildfire 2 (yes I'm part of the upgrade cycle microsoft has been talking about)
Since switching to a wide screen flat monitor, I have moved my task bar to the right hand edge of the desktop. Over there it is easily accessable and not overlapping pro/e, I find it quicker to move my mouse to the right and click on the icon that represents the window I want which will "pop it up". With this method, you need to <alt> to make the current window active. This works for me, until I have too many windows open and I have started other applications while working - that puts their icon in the nest of pro/e icons. It's either that or the "window" pull down which when used automatically activates the window selected.
Stupid question Monday follow up...."what advantage would the window pop up have?"
Radovan,
It appears you are clicking twice to get the window to change, and then doing CTRL+A to make the window active? ...or am I missing something?
With the List of Current Windows, I get from one windowto another in one click, and that click also makes the window active.
ALT-TAB followed by CTRL-A will switch windows and then activate the one you settle on. No, it's not as nice as the CTRL-TAB you can use in some apps, but it's better than nothing.
CGB
