unable to import word file in drawing
AH_10197754
I am using Creo Parametric Release 6.0 and Datecode6.0.5.1
unable to import word files in drawing.Once i did its going to not responding in creo
please explain why you need to do such action. Attach picture describing your "situation".
Martin Hanák
I need to import a word file inside the drawing. If I'm importing this nothing will happened Creo started not responding.
I have to repeat my request ... please explain why you need to do such action. Attach picture describing your "situation".
Tip: Create empty Word document object in Creo drawing and copy&paste the contents of your external document to the internal one.
Martin Hanák
