update restrected val definition
sclamens
Hy every one.
I need your help to update my restrected val definition. I used to do it in the parameter properties. But from now several days I can't do it any more. I have a mesage that says: in french (Aucun conflit détecté entre la définition interne et le fichier externe) even if I make a modification in the file *.lst that controle my parameters nothing hapens.
In my config.pro I have: restricted_val_definition S:\Dossier_de_travail_(ProEngineer)\Bibliotheque\Standard_ZFDF\Parametre.lst
What can I do?
9 REPLIES 9
when you change Parametre.lst file, you have to:
  • restart Creo
  • open model
  • update model parameters - see following picture
MH
Martin Hanák
Hello Stephane CLAMENS
Martin Hanak is correct. Best place where to "Update restriction Definiton" are starting parts.
Check your "starting files" - config options:
- template_solidpart
- template_sheetmetalpart
- template_designasm
- intf_profile_dir ( imported part profiles for *.PRT and *.ASM)
Regards
Milan Bonka
sclamens
(To:sclamens)
All my templates are Ok but I dont anderstand what the option intf_profile_dir is made for. My is not set up. What do I have to put in?
In my config.pro
intf_profile_dir ... folder for *.prt and *.asm template files used for newly created imported parts (STP, IGS etc.)
Martin Hanak is true, if you need Update Restriction Definition IN EXISTING part/assembly.
But if you want Update Restriction Definition in LONG TIME TERM, than the best way is keep your template/start parts in best condition.
Than newly created parts/assemblies will be created with "active/last" version of restricted parameters.
Both ideas got a piece of true...
Regards
Milan Bonka
sclamens
(To:sclamens)
Steel cant find the clue. I've check my *lst file it looks good. I saved it in all deferend type and tried to update the parameters in my part but it steel doesn' t work. I have the above message. What can I do?
It looks like it doesn't detect the new data I've had in the *.lst file
Thanks for your answer Milan Bonka but I dont realy understand what you mean.
Actualy I'm not an expert with this job.
Thanks for your help.
please upload your part and lst files using How to Attach a File to a Discussion Reply procedure. I will check your data on my PC.
MH
Martin Hanák
sclamens
(To:MartinHanak)
I found the source of the problem .
In Parametre.lst, 'ISO 2768 c L' value is duplicated in tg definition. Creo reports the problem during startup -  I can see following error message in Message window:
The External File for Restricted Parameters was not loaded because of wrong format.
I am sendig you Parametre.lst file without duplicate value. I guess that your intent was to enter 'ISO 2768 m L' instead of first occurrence of 'ISO 2768 c L'.
MH
Martin Hanák
sclamens
(To:MartinHanak)
Thanks a lot I didn't have the idea this could be the probleme beacause I did not undestand the error message. If this apen again I'll look carfuly
