Hello all,
I am bit confused with a building a query but it might be trivial for you people. Nevertheless I request your feedback.
I want to build a query that search for all the 'Team's with a name say 'Abc'.
Any help would be appreciated.
I'm assuming here that Team is the type of item and Name is a field in the item. As you mention that you are new to creating queries, I've included several screenshots to help you.
To create the query in the GUI:
The WebUI is similar, but the "Add Filter" button is the + sign at the bottom of the window:
You can find more details on creating queries in the online help. Here's the link for 12.0: https://support.ptc.com/cs/help/integrity_hc/integrity120_hc/en/IntegrityHelp/client_creating_a_query.mif-1.html#wwID0E3BKU
Older help centres can be found here: https://support.ptc.com/appserver/cs/help/help.jsp
