5.0 Issues with MailExtension
tmyers
I'm trying to import the MailExtension we got as part of the Thingworx Training into a 5.0 Thingworx install, and the import is succeeding but the thing is not showing up in the composer.  I get the following errors in the application log:
Unable to initialize shape for ThingPackage
    • Servlet execution threw an exception
Is there anything special I have to do to get this extension to work with 5.0?
Tim
adam11
7-Bedrock
(To:tmyers)
Hi Tim,
Is this is a 5.0 build of the Mail extension? If not, you will need to download the latest release of the Mail extension which is available from the
Downloads
page.
Adam
tmyers
(To:adam11)
Adam,
Downloading the Mail extension from the download page gets me a mail extension with a minimum Thingworx version of 4.0.  This newly downloaded extension also gives me the same error.  Is there a separate 5.0 Mail Extension that just hasn't been uploaded yet?
Also is there a list of what breaking changes there are for extensions between 4.2 and 5.0?  Mail is the only one I've had issues with using the existing extensions I had installed previously.
adam11
7-Bedrock
(To:tmyers)
Tim,
Provided you downloaded the Mail extension from the 5.0 Downloads page, you should have the 5.0 release of the Mail Extension (disregard the minimumThingWorxVersion). I was able to import the Mail extension successfully using Java 7 (1.7.0_55) and Tomcat (7.0.54). Please verify that you are meeting (and not exceeding) our system requirements (i.e. ThingWorx does not support Java 8 or Tomcat 8).
If you're still having issues, I'll setup a meeting to troubleshoot.
– Adam
elit
(To:adam11)
Was this resolved? I am having the same issue.
Thingworx version 4.2.0.41
Tomcat version 7.0.62
JVM version 1.7.0_79
