A blank page after logging to TWX Composer
SOLVED
Hi to all.
When I connect to TWX by typing "localhost" in the web address field - everything works fine. But if typed "<local hostname>" I see a blank page. ThingWorx asks me credentials in both ways.
<local hostname> = demoiot
 Windows 10
Java 1.8.0_92(64)
Tomcat 8.5.23 [tomadmin/
PostgreSQL 9.4.21
ThingWorx Platform 8.3
Some more info:
pg_hba.conf
host all all 0.0.0.0/0 trust
host all all ::/0 trust
postgresql.conf
listen_addresses = '*'
\webapps\manager\META-INF\context.xml
comment strings
<!-- <Valve className="org.apache.catalina.valves.RemoteAddrValve"
allow="127\.\d+\.\d+\.\d+|::1|0:0:0:0:0:0:0:1" />
<Manager sessionAttributeValueClassNameFilter="java\.lang\.(?:Boolean|Integer|Long|Number|String)|org\.apache\.catalina\.filters\.CsrfPreventionFilter\$LruCache(?:\$1)?|java\.util\.(?:Linked)?HashMap"/>
platform-settings.json
"PersistenceProviderPackageConfigs": {
  "PostgresPersistenceProviderPackage": {
    "ConnectionInformation": {
      "jdbcUrl": "jdbc:postgresql://demoiot:5432/thingworx",
      "password": "ptc",
      "username": "twadmin"
What is a problem?
Many thanx
P.S. I was typing "localhost" in all fields where it was needed while I was installed TWX and 3rd-party software.
pgAdmin III works fine with "demoiot:5432" server name.
Re: A blank page after logging to TWX Composer
Hi to all.
I'm sorry that I kept silent. I was trying to solve the issue in many ways (including all the advice on the top). In the end, it was easy to solve - I just turned off "Display intranet sites in Compatibility View" option in IE (see a picture).
Hi @EvgenyUraskin.
These things come to mind:
- Entry in hosts file
- Modified Server.xml file
- Firewall rule
--Sharon
Hi @EvgenyUraskin.
If you found a solution to your problem, please post it here and mark it as the Accepted Solution for the benefit of others with the same issue.
--Sharon
Hi to all.
