A potentially dangerous Request.Path
paripirala
I am unable to download ThingWorx 7.0 version from PTC website
https://support.ptc.com/appserver/auth/it/esd/product.jsp?prodFamily=TWX
This is an Assembler package. URL: http://www.ptc.com/http://support.ptc.com/esd/notfound.htm?dlm=no&wcn=457835&cn=457835&uname=pavan.a.venkata%40ge.com&ui…
Below is the error. Any help appreciated
Pavan
Server Error in '/' Application.
A potentially dangerous Request.Path value was detected from the client (:).
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Web.HttpException: A potentially dangerous Request.Path value was detected from the client (:).
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[HttpException (0x80004005): A potentially dangerous Request.Path value was detected from the client (:).]
   System.Web.HttpRequest.ValidateInputIfRequiredByConfig() +9693128
   System.Web.PipelineStepManager.ValidateHelper(HttpContext context) +53
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.34274
paripirala
(To:Aanjan)
Ravi, I used Chrome and Safari and it did not work. Same is the case when my colleagues tried to download it.
With firefox it worked.
What browser and version you used to download it?
Pavan
7 REPLIES 7
Aanjan
(To:paripirala)
Pavan, is it 7-0-1 Postgres version? Does other datecodes work?
paripirala
(To:Aanjan)
Thanks Ravi for the response.
Yes it is for 7.0.1 version and that too when downloading GE Application Assembler. The same 7.0.1 version without the GE application assembler downloads fine.
I am not sure what is there in GE Application Assembler. Do you think I can just use the regular verison of 7.0.1?
Pavan
Aanjan
(To:paripirala)
Pavan, I'm not sure where you see the link to GE Application Assembler. Can you attach a screenshot on where the link is?
paripirala
(To:Aanjan)
Please see the attached screenshot.
Aanjan
(To:paripirala)
Pavan, I was able to login via your customer number and test the download. I didn't get any error messages when downloading the one under GE Application Assembler though. Can you try with a different browser? I'm not sure what the difference is from the regular one, as this seems to be a custom package specifically made for GE. I can check internally and let you know.
paripirala
(To:Aanjan)
Pavan
Aanjan
(To:paripirala)
I personally use Firefox myself, it's currently at v45.0.1. After your response, I tried Chrome as well (43.0.2357.130 m) and I didn't have any issues there either. I'm not sure if it has something to do with your network.
