Add TriggerClick to extension widget
Chanin
Hello All,
I have create an extension widget already and I want to add TriggerClick like default ptcs-button to my extension widget
please suggestion
thankyou
nmutter
(To:Chanin)
Hey Chanin,
feel free to get inspired from my extension. I have to events defined 'ClearSelectedRows' and 'SelectAllRows'. See code here https://github.com/doubleSlashde/InfotableInspectorWidgetTWX/blob/main/ui/infotableinspector/infotableinspector.ide.js#L42
and the other files
Hope that helps!
6 REPLIES 6
bchaudhary
(To:Chanin)
Hello @Chanin
Can you pls share the version of ThingWorx that you are using?
Regards
Bhawna
Chanin
(To:bchaudhary)
Hello @bchaudhary
I'm using Thingworx version 8.5 and Eclipse IDE to compile the widget.
Please suggest and thank you for your replay
Regrads
Chanin
Hello @Chanin ,
Can you please provide me little bit more details on your request please. Are you trying to setup the default button that triggered on particular event? If possible can you please send me the Test XML file of the Mashup.
Waiting for your kind reply.
Thanks & Regards,
Surbhi Patel
Chanin
(To:SP_10367074)
I can already add a triggerClick in extension widget, anyway thanks you sir.
nmutter
(To:Chanin)
Hey Chanin,
and the other files
Hope that helps!
Chanin
(To:nmutter)
thanks you @nmutter, i can add triggerClick already.
