Hello All,
I have create an extension widget already and I want to add TriggerClick like default ptcs-button to my extension widget
please suggestion
thankyou
Hey Chanin,
feel free to get inspired from my extension. I have to events defined 'ClearSelectedRows' and 'SelectAllRows'. See code here https://github.com/doubleSlashde/InfotableInspectorWidgetTWX/blob/main/ui/infotableinspector/infotableinspector.ide.js#L42
and the other files
Hope that helps!
Hello @bchaudhary
I'm using Thingworx version 8.5 and Eclipse IDE to compile the widget.
Please suggest and thank you for your replay
Regrads
Chanin
I can already add a triggerClick in extension widget, anyway thanks you sir.
Hey Chanin,
and the other files
Hope that helps!
